It is currently Tue Sep 16, 2025 4:14 pm
PostPosted: Tue Dec 08, 2015 1:14 pm
First name: george
Last Name: s
I have '30's Washburn 00, on which over it's life someone moved the bridge. There are four holes that look like bridge pin holes about 1/2" behind the bridge. Somewhere along the way someone filled them with wood filler or dust and glue. I'd like to make them less visible. Was thinking of trying to match the spruce grain and either cutting round spruce plugs or routing a short channel on an incline, to avoid a sharp edge to the repair, and gluing in a spruce spine, then sanding flat (but I think this would show run out). Does anyone have any other suggestions? I'll test this on a scrap piece and see how each look.
Regards, GS
PostPosted: Tue Dec 08, 2015 3:34 pm
Got any pictures?
PostPosted: Wed Dec 09, 2015 1:23 am
First name: george
Last Name: s
Here you go.
PostPosted: Wed Dec 09, 2015 2:21 am
First name: Frank
Last Name: Ford
City: Palo Alto
Zip/Postal Code: 94301
Here's a classic technique for that:
http://www.frets.com/FretsPages/Luthier/Technique/Structural/SpruceHole/sprucehole.html
Cheers,
Frank Ford
FRETS.COM
HomeShopTech
FRETS.NET
These users thanked the author Frank Ford for the post: gxs (Wed Dec 09, 2015 7:46 pm)
PostPosted: Wed Dec 09, 2015 12:47 pm
First name: Big
Last Name: Jim
Interesting , Makes me wonder why they were there in the first place ?
PostPosted: Wed Dec 09, 2015 7:51 pm
First name: george
Last Name: s
Frank
This is great thank you. Now if I can do it with a portion of the aplomb, you demonstrate I'm the link, I'll be in great shape.
GS
Frank Ford wrote:
PostPosted: Wed Dec 09, 2015 8:09 pm
First name: george
Last Name: s
Wud, the approximate location of the holes would be for about 26" scale, so I wonder if this one started out life as a Plectrum Guitar and was converted at some point, but the holes are not really evenly spaced, and the neck (6 string) looks period appropriate. . . so maybe a home brew operation that was reversed. The bridge looks like a recent StewMac prepare.
It is a Washburn/Tonk, and has a 5237 stamp on the neck block, and Tonka Bros wood label inside - which is a rosewood 00. Another oddity is most of the Washburn/Tonks are EIR, this one is clearly Brazilian. The top has had it rough, but the sides and back are in great shape, no cracks. Of course it has the obligatory three holes by the endpin where someone had a tailpiece for a while.
GS
PostPosted: Tue Jan 12, 2016 10:48 pm
First name: george
Last Name: s
Well, not bad, the grain is close, now I need to decide if I want to wait 80 years for it to age, or tint it. Thanks to Frank for the tip.
PostPosted: Wed Jan 13, 2016 1:03 am
Last Name: English
City: South Bend
Country: U.S.A.
I would think that the holes were made to put screws through a caul to clamp down the bridge while gluing it back on, so I would not trust the repair itself. It is not the worst attempt at repair I have seen, there is much worse. A simple but artistic inlay will do the trick, and hide it for sure.
If what you see is what you get, then Stevie Wonder ain't got nothin'!
